Husqvarna Automower Integration plugin - Command failed
jwetzel
Hi !
I installed the Husqvarna plugin a few months ago. For a few days, no commands work and I get the message "command failed".
No error message in the console. The integration is however well connected to the Husqvarna server and I receive the status of the mower.
Is it possible to put the integration in verbose mode for error messages ?
I know that with Husqvarna's API integration there are 10,000 requests per month max, but I haven't exceeded that limit.
I tried reinstalling the integration, but the commands still don't work.
Do you have an idea ?
9 answers to this question
  • No api dev husqvarna configuration for integration plugin.  Only entry username and password.
    I moved over to HC3 and also am using this plugin. I run into the same problem. Worked fine for a few days but today it stopped working.
    The strange thing is that my iPhone app isn't that smooth as well, after starting the app, it also gives an ' not connected' message on almost the same timestamp as the HC3 QA. I recoveres after a few seconds, but if I leave it running, it again gives the 'not connected' message. If I delete the HC3 QA, the iPhone app doesn't give the 'not connected'  messages any more.......
    so they interfere with each other...... (I think)
    It's working again! both iPhone app and QA have no problems connecting. So the problem was at the Hisqvarna API
    Did you need to do anything at the husqvarna api
    cuse my plugin also stoped to work.
    no, I didn't. It magically started working again, and still does....
    have the same problem, command are not working, only get correct status.....
    UPDATE,
     this is working fine for me with my 450x
    Edited by domin12
    Same problem her.
    getting a status update of the auto mower but the command fails
    Edited by GaelP
