Integration with Nice Aria 200 gate Controller
RohitNz
The gate installer is proposing The Aria 200 system.  Supposedly by Nice.  I can't seem to find enough information.
  1. Will it integrate with Fibaro (such as HC2 or HC3) ?
  2. Is anyone using it ?
  3. Where can I find more information on it ?
Hi
I have an Aira400 and there is an integration with Nice. do to this is mono bidi i cannot see if the gate are open or closed.
I use Fibaro smart implant to control the gate. that works better i think.
I found the information on the smart implant. I did set the output to 2 sec ( so after 2 sec the switch is off again)
br Martin
  • On 7/5/2022 at 2:02 AM, Martin Windsmose said:
    Hi
    br Martin
    Fibaro responded and said only the professional version integrates.  But from the names of the products, its anyones guess as to which is the pro model.  The motherboard (unlike other gate controllers) does not have any contacts you can use.
    There was also the question of the signal reaching the gate.
    So, I have already decided to go ahead and (like you) have decided to use an implant on the gate remote (keyring model) itself.
