Everspring SP103 motion sensor on HC3
michelds
Hi, I am trying to pair a motion sensor Everspring SP103 on my Fibaro HC3, which is found, but as binary sensor and not as motion sensor.
I cannot set any parameters myself.
Can someone help me or provide a template?
Thank you.
Michel
6 answers to this question
Thank you.
Michel
I have this and it’s working great to the
last firmware and earlier firmware
I had 3 of them on my HC2, tried them on HC3 and it didn't work. I've sent this ancient hardware to the electronic recycle bin and bought new Hue motion sensors. less stress using them and much better sensors.....
  • I also need to buy 4 motion sensors for outdoor use, can you give me a suggestion?
    I use the Philips Hue Outdoor motion sensor. You can connect it via Zigbee to HC3, no other Hue stuff needed
