copy state of Hue Lamp, and set another to that exact state.
ppeterr
Hi, It's been a while since I made a topic here on the forum. Everything works smoothly as it should.
That's why I haven't touched my HC3 or made scenes for it for quite a while, and so not sure how to do the next thing.
All my lights are Phillips Hue, i only have one quickapp turning some lamps off with a motion sensor.
The rest is all controlled by a i-casa wall controller. This controller works with touch link. So "outside" of the homecenter.
This works perfect for me, since i can set the status of all lamps, and long press a wall button and it will remember the state of them all.
I have ordered a LED strip with zigbee controller. This one comes in today. But i just found out that touchlink won't work with this thing at all.
So I can't control this LED strip with the i-casa touchlink in-wall controller.
I can send it back and buy a Hue strip three times the price.
Or I can ask for your help :)
This LED strip will register as a Hue integration in the HC3 via the Hue hub. Just like the rest of the lamps. (or at least i hope so)
What I want to achieve:
When "kitchen lamp" turns on, the LED strip copies the status. So on or off AND the color state.
Below is the status output of the lamp i would like the led strip status to follow. (when turning on)
Quote
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: [HG] QA:188 Change in QA Woonkamer-Keuken
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: QA:188 any_on: false -> true
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: QA:188 Last Update: 27.07.2022 09:20:16
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting label value to lblState 2 - Partially On
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldBrightness 32
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldHue 78
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldSaturation 76
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldCt 100
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting label value to lblLastUpdate 27.07.2022 09:20:16[
27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] updateInfo:
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: Off 2.5W
Can someone help me with that?
Edited by ppeterr
  • So maybe it is a better idea to fetch variable.properties.color from the json output.
    And use those numbers for the setcolor.
    But you know me, my brain crashed also a few times now :)
    What QA are you using?
    A color device should set the color property (RGB(W)) so it should be possible to make a scene that triggers on the state and/or color value of a light and then sets another light to the same values.
    I am using petrkl12 his Huemain quickapp.
    I think it should be something like this, only then with the variable's from his quickapp for the color.
    sldBrightness
    sldHue
    sldSaturation
    sldCt
    Edited by ppeterr
    You should be able to use
    and then in the action check the state/value of the light and set the other light to the same.
    If @petrkl12 sets the 'color' property you should be able to trigger on that property to and then do a fibaro.call(otherDevice,"setColor",color) ...
    I have about six color scene's i'd like it to follow, so i think i indeed need to read out the property value of that device.
    [27.07.2022] [13:03:30] [DEBUG] [QA_HUE_MAIN_139]: [HA] ActionToggle_QAHue - Woonkamer-Hue Centris ceiling 3
    Edited by ppeterr
  • So, i recieved the lightstrip. And added it to the Hue hub. And it shows up in the Hue_main quickapp.
    I made a scene, so that lightstrip turns on when another light in the kitchen turns on.
    trigger
    action
    So when lamp 416 turns on the strip turns on. Well i got something working yeah :)
    When i look at the console, it comes up like this
    So, next thing is setting those value's above to what the actual color is of ID 416
    Any help would be greatly appreciated!
    Not that into the colors, but should
    be something like:
    Edited by SmartHomeEddy
    be something like:
    Hi eddy :)
    That actually works. And sets a certain color. But i need the value's nnnred, nnngreen, nnnblue, nnnwhite from another device.
    And then insert those into the syntax. So the color will be the same.
    ahh, does this work to get the colors?
    local colors = fibaro.getValue(416,"color")
    I don't know if that works, otherwise you could also get all parameters from a device with:
    Not sure if i understand you there, does it have to look like this then ?
    Quote
    local colors = fibaro.getValue(416,"Color")
    fibaro.call(418, "setColor")
  • For sure not, since it crashed something. Messed up the Hue stuff on the hc3 :)  -  reboot
    If it works, haven't done it before, I would expect a table from the getValue. With the fibaro.call it would be like this:
    Or it just crashes your HC3 ?
  • local colors = fibaro.getValue(416,"color")
    fibaro.call(418, "setColor", color[1],color[2],color[3],color[4])
    [28.07.2022] [17:30:04] [ERROR] [SCENE101]: (load):2: attempt to index a nil value (global 'color')
    Those are not globals i think, it must be something else. Since it is a child from the Huemain quickapp.
    I think those value's are stored different....or something, dunno.......
    Maybe, but the idea is that it follows the scene/color from that other lamp. So it is dynamic.
  • But it gives this info
    Now we only need to filter out "color":"255,203,67,0" and use that every time it switches on :)
    Oeps, it needs and extra s (colors is the variable)
  • i filled in those value's and it actually matches the color. Only strange thing is i need to click the scene about 10 times :)
    it cycle's through some colors, and then ends up in the correct one.
  • Just now, SmartHomeEddy said:
    It works with the getValue and fibaro.call(“setcolor”) ?
    No no, i just used the numbers from http://192.168.1.65/api/devices/416
    id":416,e":"afzuigkap rechts","roomID":220,"view":[{"assetsPath":"","name":"com.fibaro.colorController","translatesPath":"/assets/i18n/com.fibaro.colorController","type":"ts"},{"assetsPath":"","name":"level-change","translatesPath":"/assets/i18n/level-change","type":"ts"},{"type":"json"}],"type":"com.fibaro.philipsHueLight","baseType":"com.fibaro.colorController","enabled":true,"visible":true,"isPlugin":true,"parentId":34,"viewXml":true,"hasUIView":false,"configXml":false,"interfaces":["levelChange","light"],"properties":{"alert":0,"brightness":254,"categories":["lights"],"color":"255,203,67,0","colorComponents":{},"colormode":"ct","currentProgram":0,"dead":false,"deadReason":"","deviceControlType":51,"deviceIcon":15,"deviceRole":"Rgb","effect":0,"hue":7856,"icon":{"path":"plugins/com.fibaro.philipsHueLight/img/icon.png","source":"HC"},"isLight":true,"lightId":17,"log":"","logTemp":"","manufacturer":"","model":"","on":true,"reachable":true,"saturation":188,"saveLogs":true,"state":true,"supportedDeviceRoles":["Rgb","Rgbw"],"userDescription":"","value":100},"actions":{"setColor":1,"setColorComponents":1,"setValue":1,"startColorEnhancement":1,"startColorFade":1,"startLevelDecrease":0,"startLevelIncrease":0,"stopColorChange":1,"stopLevelChange":0,"toggle":0,"turnOff":0,"turnOn":0},"created":1658853619,"modified":1659021882,"sortOrder":128}
    Uhhhhh where
    5 minutes ago, ppeterr said:
    Uhhhhh where
    like this
    That is a json string:
    It is at variable.properties.color
  • 5 minutes ago, SmartHomeEddy said:
    like this
    Nothing,   it didnt crash either :P
    Correction, it did - unresposive :P LOL
    Edited by ppeterr
