HC3 and ROLLER SHUTTER FGR221 v1.4
Fred99
I've just upgraded from HCL to HC3 and added the first of 14 FGR221 roller shutters controllers (FGR221 firmware and HC3 Beta firmware are both up to date). However, After adding the shutter device, it will not move up or down via the app (parameter updated in settings to single momentary S1). I have poisitioning normally set to on, but even with it off, nothing happens. I have manually controlled via S1 the shutter up to 3 cycles to ensure it is calibrated but still no joy!
I added the shutter device back to the HCL and everything works fine. Am I missing something here? The HCL is unstable and it needs to be reset every 4 days so I need a more stable working solution with the HC3.
5 answers to this question
Are you using ZW3.0 Beta on HC3 or current production one ZW2.0?
That is na answer. I swap from HCL to HC3 and works perfect. Very fast, responsive system, even I am using current beta latest software release
  • The other devices work well, however I am wondering if there is an issue with the first generation of Fibaro roller shutters FGR221
  • I did a factory restart and used HC3 with Zwave 2.0 5.112.27 (beta) and everything worked perfectly.
    Clearly the HC3 Zwave 3.0 version is not compatible with older Fibaro shutter devices.
