Zigbee Range Extender
Grizzly
Can anybody help me. I have included a Aeotec Zigbee Range Extender Zi on my HC3. It appears to be working fine however, I have a couple of questions.
  • How do I know that it is now configured onto my HC3 and is functioning correctly.
  • I have added a Philips Hue Zigbee Outdoor motion sensor. How do ensure it connects (depending on physical location) to my Zigbee extender? Can I verify it?
  • The motion sensor has lost connection several times and vanishes from the devices in my HC3 the only way to reconnect is to reinclude it is using the Zigbee setup process. Is this correct?
Tony
4 answers to this question
if it get marked as dead when unplugged from wall socket, and reappears when you power it up again, then it is working.
There is no zigbee network visualization, nor any other routing information, on the HC3.
Enddevice, when including far from HC3 but near the Range Extender, should/will be included over that extender. So in the theory, when you trying to include the Philips Motion Sensor without Range Extender, and inclusion timeouts, you know you reached the "extender testing point". After powering the Range Extender on again, you can try include again, and if that works you can be sure the communication get over the extender.
For some devices Fibaro support could take a look on
, to check if the route is over the range extender (e.g. Xiaomi reports in basic cluster each every xxx minutes the parent network id as property 10), i have no idea if such information is available as well for Philips Motion Sensor, sorry.
that might be something for support.
  • @tinman apologies for the slow reply (been busy) Thank you, I am going to give it another go taking on board your information. An installer mode would be extremely useful for carrying out a site survey etc when installing devices - especially outside or in challenging environments.
    Tony
    Hi Grizzly,
    I ordered the Extender based on your post and an information that you managed to implement it under HC3. How did you that? I have HC3 on beta 5.130.45 and Aeotec Zigbee Range Extender Zi - EU version(ZGA001-C15). My HC3 uses channel #11 for the rest of my Zigbee network and I am not able to include extender into my network(Reset was done, LED fades in and out). Any suggestions for me?
    Pavel
  • On 11/5/2022 at 8:00 PM, PKB2008 said:
    Hi Grizzly,
    Pavel
    Hi Pavel,
    Only just seen your post. Unfortunately, I have been busy with other things currently and not been able to dedicate time to experimenting with both the extender and Philips Hue (Signify) outdoor motion sensor. I have just checked my system and it is using channel #20. I haven't tried including the motion sensor again yet. I will provide an update just as soon as I get time to 'play' with these Zigbee modules again.
    Tony
