Smart climate thermostat on HC3
Michael K
Hello, i'd like to control few air conditioners remotec ac master zxt 600 from wall thermostat thermostat, so i need to start this scene from any value change coolingThermostatSetpoint and need another one scene to thermostatMode off.
Here is a solution
Declarations:
And test action:
Edited by Michael K
solved
Create a QA and downoload fibaroExtra plugin to have access to event function.
then try this code
This should work. I did not try it, (sorry dont have time)...but it should work.
Edited by Neo Andersson
    then try this code
    thank you for your replay, i think that Lua scenes is simplest way and here is a solution in first post to launch this scene - if thermostat value not 0, then do actions
