Problem/bug in energy panel
Faisal Hendricks
Controlling devices by clicking the shortcut at the very top of the dashboard is really cool.
But the energy panel something doesn't work very well :/
I have your quickapp for huawei and it doesn't show the current production (on the dashboard). Production shows up in consumption.
The device type for instant power production in this integration is com.fibaro.multilevelSwitch instead of com.fibaro.powerMeter with rate type "production".
Additionally rate type of Energy Meter is incorrectly set to consumption -> this one you can change in advanced settings of this device in webUI.
QuickApp needs to be updated.
as @m.roszak already said, the QuickApp need to be updated. I'm not the QA creator, so can't change anything for you nor upload changed version, you must do the changes (or wait for updated version on marketplace).
I think following could work:
- download and install fresh copy of the Huawei solar QuickApp - do not configure it yet!
- click on "Edit & Preview" tab of the QuickApp, and then "Edit"
- open "main" and scroll down to line 140
- add comment ( -- ) at begin of the line 142
- add comment ( -- ) at begin of the line 144
- change in line 153 com.fibaro.powerSensor to com.fibaro.powerMeter
- click on save
- now change/add the IP in the "Variables" tab of the new QuickApp, click save, two child devices will get created
- double check if both are set (in "Advanced" tab of each child device) to "production"
- go to Energy Panel -> Panel settings -> Meters configuration and set both meters as production meters
- disable the old QuickApp (by setting wrong IP in it's QuickApp Variables tab), click on save
- in Energy Panel -> Panel settings -> History select the old QuickApp, select "older than", select today, click on clear and select "Compensate historical data". That will cleanup your consumption history.
- delete the old QuickApp
/monthly_2022_09/image.png.854826eacc06d0b66d7cba578fc7d975.png" />
  • 9 months later...
  • @tinman You are the best! The solution worked. Too bad QA still hasn't been improved by this time. Maybe you could post a link to your fix in the comments?
    And, of course, the fix is still needed for it to work. It should be changed:
    local readHoldingRegistersFrame = string.char(0x00, 0x03)
    to
    local readHoldingRegistersFrame = string.char(0x01, 0x03)
    @Daniel Smaart yeap ;)
    • 3 weeks later...
    Witam
    U mnie się nie łączy. Mam taki bład:
    • Class for the child device: 173, with type: com.fibaro.powerSensor not found. Using base class: QuickAppChild
    Zmieniłem port na 502 i zaczoł sie łączyc, (dziwne bo wcześniej taki miałem) szczytuje dane ale wyświetla błędnie taki mam komunikat: main.lua:37: attempt to call a nil value (method 'setValue')
    /monthly_2023_07/image.png.4e399d389147be1c37558544b1746358.png" />
    • 1 month later...
    Witajcie.
    Wprowadziłem wszystkie modyfikacje o których piszecie ale HC3 cały czas nie pobiera danych.
    Czy możecie sprawdzić czy integracja działa Wam w tej wersji oprogramowania>
    • 2 months later...
