Roller Shutter 3 not reporting their status anymore
Fly
Everything was fine before I updated to 5.120.10 but now:
- the icon looks different
- when I press on the physical button, blinds are moving but position is not reflected anymore in the application (iPhone and/or web interface).
- when setting up a xx % in app it works fine but when I asked the blinds to go up completely again (or down completely again), they do not take into account the xx % previously set, they go ups or down for 100% (and 100% of time - forcing motor at the end).
Do you also experienced that ? Is there anything specific to parameter to correct that behaviour ?
Thanks,
Fly
Edited by Fly
Title edit
  • In fact, the main problem is status return. Can you please confirm, for those using FGR-223, that when you manually set the blind down for example (with the physical button close to the blind), then the status is correctly reported on FIBARO App ? I remember it was working fine (but I have doubts now !!!), as it looks like it does not work anymore... Anything due to latest build or is there any settings which was modified and I do not find ?
    Maybe I will try if I can have answers on that post:
    Thanks,
    Fly
    Edited by Fly
    • Fly changed the title to Roller Shutter 3 not reporting their status anymore
