Kohen-NL 0
I've added an Heatit ZM thermoistat 16A to my HC3
It has an own thermostat and connected it with an infrared panel (450w)
The question I have is how can I connect the schedule with the thermostat from the Heatit. Somehow it takes a different thermostat value.
For example it is 21 degrees upstairs, and in the living room it is 19.
When I put the schedule on 18 degrees it is still turned off, when I change it to 19 still nothing but when changing it to 20 it starts to heat.
But why?! His own thermostat is still 21... How can I change that?
Did I miss something?!
6 answers to this question
