Fibaro relay without a switch for Porch Light
Nis
Hi all,
A quick question as I'm starting to add more Fibaro devices to my system.
I have a porch light which I would like to control via Fibaro.
Currently I have an outdoor socket from a fused spur inside the house. I have a plug in that outside socket which is wired upto a light sensor and from there goes to my porch light. I would like to remove the light sensor as it rarely works and replace it with a Fibaro relay. The outside socket is always 'on' so I don't need a switch for the relay. I would like to put in a waterproof inline connector where the light sensor is/was and then place a Fibaro relay in the porch near the light. (under a pitched vaulted roof).
Can this be done?
Regards, James.
0 answers to this question
