yes, this is how it is currently implemented, it does use only ZIGBEE set rgb.   Please login or register to see this image. /monthly_2022_10/image.png.c1e23a18eef1fef6c5fe041fd0faff55.png" />   You can for sure set fav. colors (API or any other z-wave rgb/rgbw device), to try to cover more or less what you wish, but only with RGB value.   You can use zigbee API to Please login or register to see this link. , this can be rgb, xy. Haven't found yet was to change for my HUEs the col
    1
