Urgent help needed please -RGBW modul state reports
Neo Andersson
Hello guys,
I have a problem that RGBW modul reports its state only after 7-8 second to the controller.
I have tried set parameter 151,152 for trsansition time, maybe that could help, but nothing..
The connected led turns ON/Off immediatelly but the state of the RGBW changes only after 7-8 sec.
So only after 7-8 sec i get the correcgt result for hub.getValue(ID,"value").
Please anyone any help?
5 answers to this question
Hi @Neo Andersson,
Please, set up remote support in HCs Access settings and create ticket to Fibaro support ([email protected]). Then call them via phone that issue is urgent and ticket number you received from their system. Number is
Any solution? I have noticed it in several installations now, it is even slower when sending a command to several rgbw modules at the same time.
  • 2 hours ago, jakub.jezek said:
    Hi @Neo Andersson,
    Hi, I did it. Ticket number is #234442
