FGS-223 adding Heat detector and three Binary Switch
seglarn
Can anyone tell me why I get there Binary Switch and Heat detector when I added FGS-223 to HC3?
seems that 22.0 and 22.1 Binary Switch triggers the same function…
3 answers to this question
Hi, you should only see the two switches and the scene controller like below.
I recomend you to exclude/include the fibaro module from hc3 again.
  • @FabirHi, I have tried this but still get these. Doesn't matter which Fibaro switch or dimmer  I add to my HC3.
    Could it be related to the fact that I selected Z-wave 3.0 during the installation?
    @seglarn
    Hi, I have had installed a hc3 with the ZW3.0 engine and have ongoing very bad experience. Some strange behaviour. In my case the hc3 has less z-wave range than the previously installed old homecenter light with some zwave mesh devices.
    I had open a ticket with fibaro support, they have told me the ZW3.0 engine is not yet in Alpha status. This hc3 is at a friends house. Next time I can to go there, I will have to reset it and go from scratch with ZW2.0
    Unfortunately this is not noticed in the online user manual of hc3, if I knew this before I would never had used the ZW3 engine.
    I recommend you to do start again with ZW2.0
    Edited by Fabir
