Turn off the dishwasher and induction cooker via fibaro
Krystiann
I want to turn off dishwasher via Fibaro but it uses three-phase current . Do you recommend some switches for that?
7 answers to this question
QUBINO 3-PHASE SMART METER + BICOM432-40-WM1
@Krystiann
Hi, for the 3 phase load you can use any fitting elcetrical switch-relay
Than thurn on/off the Switch-Relay with a fibaro switch modul like the fgs-223 / fgs-224 etc.
look here:
  • 2 godziny temu, Fabir napisał:
    @Krystiann
    look here:
     Do you think true Switch-Relay will survive that load?
    @Krystiann
    Hi, thats why I wrote a fitting electric relay-switch with a 3 poles like this contactor here:
    Off course you need to check how much current is going trough the 3 phases.
    With the fibaro module you only switch on/off the control circuit off the contactor. Then the contactors main 3 phase poles are switching the load.
    If you don't know about this matters, you'd better ask an electrician to install it.
    Electricity is dangerous
    Than you only need to configure the Fibaro module.
  • Yeah I know that it is hard but I am asking about how module communicate with Fibaro because in product page I didn't find any information about z-wave
