  • 3
Goodwe HC3
Martin555
I did it. I have QA for local connection with HC3 and Goodwe  series like in Homeassistance for ET, EM and DT series. QA are down on sites. If you wnat help or if you want QA contact me with message
/monthly_2022_12/image.png.c37acb323622ce95f9d6fe563f7c7d5a.png" />
Edited by Martin555
  • Like 3
  • HI , I have QA for local connection with HC3 and Goodwe  series like in Homeassistance for ET, EM and DT series.  If you want QA or help contact me with message here or you can contact me on faccebok messanger martin.potocky.18 or email [email protected].
    This is my for EM series.
    • Like 3
  • .If you want QA fo ET, EM, ES or DT serries contact me via message
    Edited by Martin555
  • So I had a mistake. I print bad table.
    -- UDP Quick App Data from inverter Goodwe
    function QuickApp:onInit()
        self:debug("onInit")
        self.ip = self:getVariable("ip")
    ---- Searching after inverters on the network ----
    function QuickApp:searchInverters()
        self:debug("Searching inverters by broadcast to port 48899")
        local payload = "WIFIKIT-214028-READ"
        socket = net.UDPSocket({timeout = 3500, broadcast, true})
        socket:sendTo(payload, "255.255.255.255"48899, {
            success = function ()
                self:debug("waiting for response inverters...")
                socket:receive({
                    success = function(response)
                        print("response")
                        socket:close()
                    end,
                    error = function(error)
                        socket:close()
            end,
                print('Error:', error)
    ---- Request about inventer model and serial number ----
    function QuickApp:discover()
        self:debug("Probing inverter at")
        local payload = string.char(0xaa,0x55,0xc0,0x7f,0x01,0x02,0x00,0x02,0x41)
        devicesTable = {}
        socket:sendTo(payload, self.ip1, 8899, {  -- IP adress inverter
            success = function()
                self:debug("waiting for response model type...")
                socket:receive({
                        modelName = string.sub(response,13,22)
                        serialNumber = string.sub(response,39,54)
                        print(modelName)
                        print(serialNumber)
                        self:updateView("label3","text","Typ:  "..modelName.. "\n   S/N: " ..serialNumber)
                        socket:close()
                    end,
                        socket:close()
    ----   sed UDP pracujuce ---
        if self.ip ~= "changeme" then
             data = string.char( 0xaa,0x55,0xc0,0x7f,0x01,0x06,0x00,0x02,0x45)
              devicesTable = {}
            local socket = net.UDPSocket({timeout = 5000, broadcast,true})
            socket:bind(self.ip, 5061)
            socket:sendTo(data, "192.168.1.149"8899, {  -- IP adress inverter
                    -- self:debug(data)
                    self:debug("waiting for data ...")
                    self:receiveData(socket,devicesTable)
        else
            self:debug("the HC3 IP not entered in local variable")
    function QuickApp:receiveData(socket, devicesTable)
        socket:receive({
            success = function(data)
                table.insert(devicesTable, data)
                self:receiveData(socket, devicesTable)
                print(data)
                AA = string.gsub(data,"(.)",function (x) return string.format("%02x",string.byte(x)) end)
                print(AA)  --- DATA INVERTOR
            end,
                self:handleDiscoverResponse(socket,devicesTable)
            end})
    function QuickApp:handleDiscoverResponse(socket,devicesTable)
     -- self:debug(json.encode(devicesTable))
      data2 = json.encode(devicesTable)
      print(data2)
     self:debug("data received, closing UDP")
     socket:close()
    Today I have a data with this :
    aa557fc001868c0e7500010105b200000001e30003005000ff00050064006400001200125f01000001092f000100db138301092f0009007513800102011d000000000001de2e00006f708acd898d00027ae5000c01003002007300010000ffc301080006000016031d05292d0000000000000000000000000000000000000000000000000000d3d50000b6a00200000000000016f9
    So it is same data like HA.
    Maybe probably, somebody to help me translate data into variables like in HA  Isn't there someone who knows the phython and would be able to help translate code to LUA?
    Edited by Martin555
  • I have it first experimenal. It is working  I have now some values.
    /monthly_2022_11/a.png.493dee5758348263e41f3580cc75becd.png" />
    @Martin555 I also have that solar inverter and I am really interesting in create a quick app for it. Could you share your current version? It will help me. I have experience with this kind of integrations so probably I can improve it and re-share again
    thnx in advance
  • sure. This is QA which I have now.  if somebody want here is my QA for Goodwe EM series and QA for ET series.
    /monthly_2023_01/snimka.jpg.fea808ead7f417229d88a302886dfead.jpg" />
    1. child - instant FVE produktion PV1 and PV2
    2. child - Battery
    3. child  instant home consumption
    4. child  instant pgridd from network
    5. child instant pgridd to network
    6.  child TodaysPVGeneration
    7. child Battery impoort
    8 child Day home consumption
    Edited by Martin555
  • For ET I do it now. You have to wait. I have now this. If you want new with child send me message
    Edited by Martin555
    GoodWE makes a lot of different models.
    I Tried both QA's on my GoodWe GW5000-DT 3-phase model but no replies and no data unfortunately.
    I bought a HomeWizzard P1 that can read out my smart electricity meter so I do get some insight in my solar panels.
  • I aslo have for DT . For DT is commnd -
    (0x7f,0x03,0x75,0x94,0x00,0x49,0xd5,0xc2)
     That's basically qa. IF you manage to get the data, then the data will only be distributed.
    Edited by Martin555
    Thanks! I Will give it a go tomorrow and let you know.
    Hi Martin, perfect, it works like a charm for one of my DT models.
    The second one is telling me it's waiting for data but nothing seems to happen.
    The other one is excellent ! Thumbs up!
    (Oh, and one minor detail. It would be nice to have the description of. the child devices in the main dashboard also in English :) )
    Edited by GeeMoney
    Sorry , That I that I don't have a description of the English language, but I can help with the translation and adjust the chili according to your needs. Everyone has different needs.
    Problem is clear. My other Inverter's firmware version is too low and local UDP is not enabled in my firmware yet.
    I Have asked Goodwe for a newer firmware level but not sure if I can get it as support seems to be gone already for this specific model.
    Anyway, if you have a recent firmware or DT model Inverter the QA works perfect !! Thanks Martin for the great work.
    Nice, I'm also going to give this one a try and see what I can use / re-use.
  • Hi,
    I have a new version for EM series. This version has a new Days  and Years values.  If you want to try or help , if you have QA contact me with message.
    Edited by Martin555
    Good afternoon Martin. My second Goodwe is now also working as expected ! Many thanks for these great QuickApps.
    Goodwe has upgraded my firmware remotely and now also sends out UDP traffic that is received by your QuickApp.
    So now I can read out both Inverters and receive metrics. Excellent.
    I am a happy.
    Hello, have you Apps for goodwe invertwer yet ? Could you send me please ?
