Update device parameters in the REST API
Lenfors
Hello!
I read all my units from my HC3 with the command http://<username>:<password>@192.168.70.31/api/devices
In the response I get all the parametes for the units.
Now I want to change parameters in the units, what is the syntax for this?
Please give an example if I want to update parameter 28 on UnitId 123 to value 15.
Best regards, Mikael
  • Ok, your call is from LUA, but how is the call from the REST API?
    It should be something like: http://<username>:<password>@192.168.70.31/api/ .....
    Check Swagger on your HC3 for the API documentation:
    https://hc3-ipaddres/swagger/
    I think you need this:
    PUT devices/modifyDevice
  • Yes, I read the documentation but I dont understand it!
    If I could only get an example it would be so much easier :-)
    When  I use Google Chrome I can enter  http://<username>:<password>@192.168.70.31/api/devices  in the URL to get a JSON response whit all my device info.
    What should I enter to set a a parameter on a unit?
    Best regadrs, Mikael
    First, give us some more information. And what do you want to accomplish...
    Do you want to change the device from the HC3 itself? With a scene/QA, or a third party service like Node-RED?
    Please read some information about how the REST API works, based on the HC3 I wrote a blog about the REST API, how it works.
    To answer your question, you can't do a POST or PUT command in the browser URL bar. You have to use some software like Node-RED, PowerShell, curl, etc... (Google them).
