CALCULATIONS WITH VALUE
FBoh
I wanted to use a value from sensor (energy consumption) and use it in calculation of new value, which
will be then shown in dashboard or elsewhere.
Has anyone any clue how to program this?
Thank you in advance.
FBoh
Maybe create a quickapp, get the value, calculate your thing and update the property of your quickapp.
Here are two important manuals how to do that:
    Thank you for instructions. Maybe someone already have this kind of quickApp?
    @FBoh
    @FBoh Your input is so general that SmartHomeEddy wrote the best thing possible.
    Write more... or better, you will become interested in LUA, learn, try,... and ask questions. There are people here who will help you reach your goal.
  • Yes i would be better if a will find the time ;)
    I'm using power meter (from SolarEdge) to track the consumption of a building. I need to
    see only on part of consumption, which is approximately 40% of whole consumption.
    So i would need an app to use one value and calculate another and show it.
    This is simple for some people i presume.
    Thank you.
    • FBoh changed the title to CALCULATIONS WITH VALUE
    • 3 weeks later...
    @FBoh
    ...and can't it solve your requirements??..
    SmartHome Eddy is handy and gave this QA.
    It probably won't be a problem, or modify this QA and calculate what you need.
    @SmartHomeEddy
