Weider 1
I am having an issue with my Fibaro HC3 where my scenes are no longer running properly.
Initially, I noticed that one device was not turning off when it should have when another device was turned off.
Now, my automatic scene that runs at midnight is also not running along with some other scenes.
I am unable to run it manually as well, as pressing the play button does not produce any results.
I am currently running the latest firmware.
After reboot I was able to manually launch the scene again.
Has anyone else experienced this issue or have any suggestions on how to resolve it?
Thank you in advance for your help.
Edited by WeiderLink to comment
1 answer to this question
