Fibaroextra 0.955 - event error
Neo Andersson
Jan, can you please check this..
It throws me error when updated to latest Fibaroextra, and it was working months before update.
main.lua:15: attempt to call a nil value (field 'event')
Edited by Neo Andersson
Well, you were lucky in the past.
fibaro.event(...) should not be used before QuickApp:onInit() is called. The reason is that the order of the loading of the files of the QuickApp is not guaranteed.
If 'main' is loaded before 'fibaroExtra' you can't call fibaro.event(...) on top-level in 'main' because fibaro.event(...) is not defined yet.
The way to do it is either lifting in the code above inside QuickApp:onInit() or wrap it in a function called from :onInit()
Ex.
    Ex.
    ohh okay, thanks, i think i cant update all my QAs to latest Fibaroextra..as i used event function calls many times like in the example...
    Well, if you do that you are playing file-order-roulette and your existing QAs may start to throw errors at restarts. You have just been lucky so far.
    It's actually a general rule when developing QAs. If you have a multi-file QA, don't use functions defined in the other files until your QuickApp:onInit() has been called.
    Thank you for the advice..
    • 2 months later...
