TTLock connectivity?
iTibor
Hi
I would like to include into HC3 a smart lock based on ttlock   (
Could you help me ?
Hi Tibor,
I use a number of ttlock based locks.
My understanding is that the ttlock systems uses wifi for remote connection and local connections to the ttlock gateways, but uses bluetooth for comunication between the ttlock gateways and the locks themselves?
If this is the case, I don't know how the HC3 could be involved?
However, if you do find a way to link the two systems, I would be very interested in doing the same thing.
BTW, what do you want to use hc3 for, does the ttlock software not give you the control you need?
Phil
  • Hi Phil,
    First of all I would like to use only one app for smart devices, for example with one command, like to close the front door to turn off all lights, arm the house, reduce the heating... which are under Fibaro HC3
    Tibor
    According to the API that I looked at, Bluetooth is always used and that of your phone.
    It is possible to use an ESP32-type intermediary that can communicate with the lock using bluetooth and with servers using api. Similar to the gateway for the Xiaomi thermometer.
    i actually wrote already QuickApp for TTLock, remind me on next weekend, so i will post it
  • @tinmanThanks
    I'll remind you next week 🙂
  • Hi @tinman
    A week passed, I'm here to remind you 😉
    Tibor
    Hi
    Did you manage to write the QuickApp?
    • 1 month later...
    @tinman  nothing ?
    On 3/23/2023 at 1:26 PM, iTibor said:
    @tinman  nothing ?
    yeah sorry, being busy with lot of projects, will post something over the eastern
    • 1 month later...
  • Hi  @tinman
    Did you manage to deal with the code?
