Swagger to Scene LUA syntax
Corceiro
I'm trying to learn and do more complex stuff but I've having issues with the correct syntax from Swagger to LUA Scenes.
I'm trying to change the Energy Consumption and Production Meters on the Energy Panel through a scene.
I'm trying something like:
api.put("/energy/settings",{"energyConsumptionMeters": [649] })
to make my energy meter device n. 649 a energy consumption meter on the Energy Panel, but I get the error [ERROR] [SCENE220]: (load):1: '}' expected near ':'
I tried different syntax and searched a lot on Google, but I'm not familiar with LUA code and can't quite get, yet, how to use the API.
Why doesn't it work like the syntax I use to enable and disable some devices on LUA Scene:
api.put("/devices/"..653,{enabled=true})
api.put("/devices/"..654,{enabled=false})
Shouldn' t it be the same?
I was also trying something like
api.put("/devices/"..653,{saveToEnergyPanel=true})
But it doen't work either...
Can someone give me a brief explanation of what I'm doing wrong (or some link or papers were I can learn how to do it)?
Thank you very much for your time.
Edited by Corceiro
7 answers to this question
api.put("/energy/settings",{energyConsumptionMeters={649}})
saveToEnergyPanel is a property so
api.put("/devices/"..653,{properties={saveToEnergyPanel=true}})
from a QA this works:
from a Scene it is another another json encode so you need to bring out the sledge hammer...
    Perfect!!! Thank you very much!!!
    What if I want to clear that option. In other words, If I don't want any Energy Consumption Meter on the Energy Panel?
    I already searched and tried some code lines. Neither of them give any error, but don't work.
    I tryed:
    api.put("/energy/settings",{energyConsumptionMeters={}})
    api.put("/energy/settings",{energyConsumptionMeters={""}})
    api.put("/energy/settings",{energyConsumptionMeters={0}})
    api.put("/energy/settings",{energyConsumptionMeters={null}})
    api.put("/energy/settings",{energyConsumptionMeters={ }})
    Edited by Corceiro
    It worked! Thank you very much! I still don't quite understand the syntax, but getting there with this examples.
    Thank you very much @jgab. Hava a wonderful weekend!
  • Good morning @jgab.
    If I may ask, where do you find the documentation to keep you up to date with Fibaro coding?
    Things like function(e) are Fibaro exclusive syntax coding or ir general LUA coding?
    I wanted to learn a lot more (only for personal amusement and entertainment myself) but, beside this Forum, I'm struggling to find papers or books where I can explore self-learning.
    I'm also exploring YAML with Home Assistant (HA) and found that HA as a very good documentation site, but can't say the same about Fibaro (or I still didn't find it).
    5 hours ago, Corceiro said:
    Good morning @jgab.
    It's mainly standard Lua, where Fibaro actually removed some standard feature like coroutines and metatables for no good reason and other like os.system() for security reasons.
    Then Fibaro has added a couple of Lua libraries they developed themselves , like the fibaro.* , the QuickApp:* functions, and added some like the net.* and json.*
    Scenes has that home made trigger model that filter events before invoking your scene code...
    Fibaro has always been slow to evolve the Lua framework and document it. That's why you see a much more features and a more vibrant developer community for HASS etc... which is a real pitty.
