Note, Please login or register to see this link.
This setup is designed for QA development using Visual Studio Code (VSCode). It includes an emulator, allowing you to run and debug QAs directly in VSCode. This setup is compatible with HC3, offering features such as code completion, syntax highlighting, and workflow tasks for downloading, editing, packaging, and uploading QAs to/from HC3.
Tested on Windows 11 and MacOS, this setup should also work on Linux.
You can download the r
