Hi.
I have  a "linked device"  Thermostat which is set up as follows:
/monthly_2023_11/image.png.d323dd84203dc3a67424857f5efb08a4.png" />
The Thermostat setting are this:
Every time the temperature sensor "Ceiling@Office" updates the temperature, the Air-con switches OFF - WHY?????
I find this in the history:
The Ceiling@Office sensor is clearly above the cooling temperature!
There is NO association between the ceiling sensor and the air-con!
I can not figure out why this is happening :-(
What am I missing here?
Any ideas??
Thx for helping
Edited by pflugj
added TAGS
12 answers to this question
It seems to me that there can be 2 answers
1. this is a bug in the system related to setups where the heating and cooling device s the same,
2. ther can be some other issue with connection stability to the temperature sensor. Does the temperature sensor have a stable connetion? Is it a batter powered one?
Side question / how is your AC connected to Fibaro?
7 hours ago, pflugj said:
Hi.
Any ideas??
Thx for helping
Maybe the climate chedule itself? How is it set?
    Hi I also checked this a couple of times
    When editing the temperature Zone I get this:
    /monthly_2023_11/image.png.0282022e4d5e082274134d539c22d880.png" />
    ....and after a few seconds this
    The "Select zone temperature sensor:" is EMPTY 🤔
    Sometime it is missing and sometimes it is not!
    And I always reconfigure the zone to the right sensor:
    ...and after saving the zone.
    The sensor is sometimes missing - AGAIN!
    However, the zone setting are very simple
    I just disabled the Zone to avoid interference from here:
    If the thermostat initiated a switch On/Off, then I would expect to see something like this in the history:
    BUT this is not the case:
    The Sensor changes value and the Air-con switches OFF!
    .... and I still donẗ see why 🤔
    thanks for helping
    This did NOT happen in FW: 5.141.59
    It happens in the the next and the current version  5.150.15
    I had opened a support ticket on the 20 Oct,  but only got a reply, late last night - but so far NO solution
    The Air-con toggles ON/OFF with EVERY temperature update
    Hi.
    The AC is switched by a
    Fibaro Double Switch 2 FGS-223
    The sensor is a battery powered
    Fibaro Motion Sensor FGMS-001
    Both are less than 2 meters from the HC3
    The switch is just disconnecting mains from the unit.
    I verified with the installer that the unit can handle mains on/off switching.
    (It is a split unit with an inverter, not the old compressor ON/OFF type)
    I did report this to Fibaro but so far NO solution
    @pflugj I've also had issues with climate zones and virtual thermostats (linked devices)
    Below is just my experience, and how I got them running successfully.  I don't claim, this is the only solution.
    Make sure the linked devices, temp sensor and switch module, don't have any associations with other devices.
    I also don't use the climate zone temp sensors, in a scene.
    As long as you can't setup the climate zone with the virtual thermostat (linked devices) successfully, this won't work.
    Maybe use another temp sensor temporarely.
    In my case, I don't use battery powererd temp sensors any more, for climate zones.  I've tried with the fibaro motion sensor and the smoke sensor
    As temp sensors for my climate zones I use:
    Aeotec multisensor 6
    Fibaro Smart Implant with BS18B20 temp sensors
    Fibaro walli controller
    All with power supply.
    Edited by Fabir
    Hi.
    more, because the main controller is NOT aware of those direct interactions ( as far as I know)
    as I wrote before , this did NOT happen in FW: 5.141.59
    So I restored that version and it works as intended!
    I guess that the new Thermostat "Hysteresis" settings, has something to do with this.
    Thanks for helping, cheers and happy home-automation :-)
    What would we do, with all the spare time :-)
    For your interest:
    Fibaro has changed the thermostat behavior.
    This is what I received yesterday:
    Quote
    A heating device will be turned on by the logic related to the heating, but simultaneously turned off by the logic related to the cooling (analogous situation if the current temperature would be above the setpoint).
    Which makes sense, when using different devices for heating and cooling!
    This does obviously does NOT work, when the same device is used for heating and cooling.
    I think this behavior is a bug, when using the same device!
    ... and should be rectified or somehow be tackled by Fibaro
    I did set my aircon to automatic mode ( heat or cool) at a temperature, somewhere between the set-points for heating and cooling.
    Thus effectively increasing the hysteresis between heat and cool.
    ...and even more important, saving power
    For the time being, I have removed the Air-con as heating device from the thermostat.
    At the moment I see only one way to get this working again as intended:
    Creating 2 thermostat's, one for heating and one for cooling.
    Cheers and happy "home-automation" 😀
    was right!!!
    Quote
    @pflugj Hi, thanks for the infos.
    If I understand correctly, the fibaro climate zone on fw 5.150, can't work, when the heating and the cooling device, have the same name.
    Did you try use one chanel of your FGS-223 for heating and the other for cooling? Both Q1 and Q2 connected to your aircon. Give each of the outputs another name.
    Just curios, which brand/model aircondition with cooling/heating, are you using?
    No, I didn´t try the different outputs.
    This might actually be a nice idea👍, because I could then distinguish between "heating"and "cooling" power end energy consumption.
    I will try that if Fibaro does not come up with a fix for this
    At the moment I will not do this, because I am switching the air-con of when a window or a door in that room opens.
    Therefore I have written a LUA scene, which disables the "Thermostat" and the assigned "Climate Zone",
    When a door or a windows is opened for more then "X" seconds
    The air-con brand is "MIDEA"
    The have a feature cold "AUTO-START"
    Meaning: AFTER a power-cut,  it remembers the last set mode!
    cheers
    Edited by pflugj
    spelling corrected
    What you are describing usually happens when the system is not simply “reading” the ceiling sensor, but actually using it as part of a control decision after the firmware update. Even if the temperature shown at the ceiling is above the cooling setpoint, the controller can still switch the aircon OFF if that sensor is tied into automation logic, a zone controller, or a feedback loop that was modified in the newer firmware versions. The fact that everything worked on 5.141.59 but started failing from 5.150.15 strongly suggests a change in how sensor inputs are interpreted rather than a physical temperature issue.
    In many modern office HVAC setups, especially where ceiling sensors are part of a broader zoning or BMS-style control, the wiring and logic relationship matters more than the visible reading. A sensor can look “independent,” but still be assigned indirectly through scenes, safety overrides, or energy-saving rules that trigger shutdown when readings change rapidly or appear inconsistent. This is also where installation design becomes important, because routing, zoning, and controller mapping need to stay consistent even after software updates. Some practical context on how these systems are typically structured in real installations is reflected in SoCool’s aircon setup approach, and related system design considerations can be seen through their installation
    , which highlights how sensor placement and system layout often influence overall control behavior more than expected.
    Given the pattern you described, the most likely explanation is a firmware-side change in automation priority or sensor handling rather than the ceiling sensor itself being faulty. If reverting the firmware immediately stops the issue, that would essentially confirm it.
