How to filter devices upon multiple types
Neo Andersson
Hi
Anyone have some suggestion, how can i list all devices that have either com.fibaro.baseShutter or  com.fibaro.FGR basType and are visible?
It works with one type like this
but doesn't work for multiple types
thanks
10 answers to this question
You can retrieve them like this.
  • Yes I know this, but i was hunting solution for the other endpoint..
    There are two endpoints (actually 3)..First can manage the shutter and the slats using setValue or setValue2
    The other is for slats only, using setValue, and the third is for shutters also using setValue when accessing it.
    Anyway thanks
    I don't get what you want to do.
    What is "the other endpoint"?
  • Please login or register to see this image.
    /monthly_2024_03/image.png.e61e9e8dfdc7995d5dde9d21d9615d18.png" />
    Enpoinst 631,633 634
    I don’t get what the question is.
    You search for “a solution” for “endpoints”. What are you trying to accomplish? Please be more specific when asking for help.
  • If ai am using a filter "
    it will get me all the 3 endpoints..So later in my code, when I access the filtered data, it will affect all three endpoints, because all of them are of rollerShutter type
    So i need to filter only 1 of them, possibly in my example the 633 because using that i can acces both the lamels and the shutter using setValue and setValue2 commands
    Its kinda tricky, becuase we not always have Fibaro moduls.. They can be other blid brands, they can even be a QA devices..
    So i need to list all the blind type devices in a room, and later apply to them a value..But as i mentioned, i can not filter on type..
    If i did, it will affect unwanted devices too
  • Actually i was wrong 633 is not of type rollerShutter it is com.fibaro.FGR223, so there are two of them.
    Anyway, the best would be if i could filer on multiple types.. that is my goal in one word..
    Why not retrieve 3 lists and then combine them into 1 list? Then work with that list.
    Edit: reading your last post again, you ask for 2 different things. Filter out 1 device from a list and get all devices of a specific type and send a commando to all of them at once.
    Edited by Joep
    I don't understand the question.
  • My original question was how to filter devices on multiple different types
    All other stuff that i wrote, just evolved from conversation.
    The question still remains the same..Using any api call, or whatever other method to filter two or more device types...thats it
    Using multiple different calls is a clear solution for me, but i was asking if it is posssible in one call.
    Probably not..thanks
    As I’m aware off, that is not possible.
