Dear Community,
I am experiencing a strange behaviour that I consider a bug.
Environment:
I am using a HC3L for heating including radiator and boiler control. I have a thermometer and a valve actuator in each rooms but no physical thermostats.
I'm using QuickApps as virtual thermostats to store setpoints. Climate schedule sets these virtual thermostats that also can be overridden manually. The heating scene is comparing thermometers' and virtual thermostats' values to control the valves and the boiler.
Expected behaviour:
In the HC system the manual override is always set for a specific duration and it has the highest priority. When I override the climate schedule for a device (a room) I expect that the override will be in action until the duration runs out regardless the setpoints meantime. After that the room's setpoint gets reset to the then actual scheduled value.
Problem:
In practice the manual overrides are always get reset when the schedule reaches a setpoint. Since overrides are set for an exact duration this behaviour seems faulty alone. But the situation is even worse: the overrides are always get reset when any zone's schedule reaches a setpoint! That means if I turn the heat up in the living room for the evening movie time it gets reset in every half an hour, even when the towel dryers stop heating in the bathroom. What makes this bug even worse is that not needed setpoints cannot be disabled in the schedule.
It can be a partial workaround if I modify the schedules to avoid the most of the interference but it's not an ultimate solution. I started to develop this system to make the usage more comfy for my family but this bug makes it harder to use.
I've updated the OS recently to 5.170.16 from a years old beta but I didn't try overriding before so I don't know if it worked correctly with the old OS.
Thank you in advance
Edited by Komate
Seems to me a bug. Send a report to support.fibaro.com
 @Komate I'm also using overrides for my unterfloor heating. In the evening I'm running block scenes with intervalls to override the climate schedules. These intervalls do not get overriden when a setpoint is reached. This sems to have not the same behaviour, as your quickapps.
If you use your override quickapps only in evenenings, move the setpoints out of the way, as you already have mentioned.
