Hi all,
So I've noticed that there are two types of icons that I cannot seem to change in HC3 (not sure about other platforms).
I have a number of Fibaro dimmer 2 modules in my house and I cannot seem to change the icon for the secondary switch (which I have running other devices) nor the parent (actually I cannot change the icon of any parent).
There is also an issue with the open weather map QA1.1. I can change all icons except the parent. Actually the icon does change before the QA changes it back 1/2 second later.
Does everyone else have this issue? Is there a reason for it? Can Fibaro change that in a future update?
Thanks,
Anthony
3 answers to this question
3 hours ago, Anth said:
Hi all,
Thanks,
Anthony
the parent in this pic isnt ment to be shown and cant be changed as you experience (34) :D
The QA weather map might have something in it selv that change icon depending on weather condition so that is why it changes icon back again :)
And I can change icon on 35, 37,38  the remote device isnt possible to change anymore, since some updates ago 🤔
This is a Fibaro dimmer 2
If you really want to, you can change the icon property with a lua line if code.
Weather provider QA that I published on Fibaro marketplace and here in download section can use user custom icons on web GUI (in browser), but in mobile app it still forces Fibaro original icons.
