Ok I have a scene that is only meant to turn on a light when PIR trips and the LUX is less than 45 the light should turn on. Problem is the light turns on
no matter what the Lux is, even if I set it to Lux == 3 it still turns on. I have tried this with several Magic Eyes.
conditions = { {
id = 80,
isTrigger = true,
operator = "==",
property = "value",
type = "device",
value = true
id = 82,
isTrigger = true,
operator = "<",
property = "value",
type = "device",
value = 45
operator = "all"
try with lux as optional condition and not as trigger :
Btw, ensure you did changed parameter 40 from the motion sensor, with default value of 200 it will not recognize values such low as 45
Edited by tinman
