Basically I want to check a certain device if it's marked as dead and then send the command to wake up.
I have one switch device that's up two stories and one other switch is in between but sometimes the command doesn't get there and when I check it's marked as dead.
But when I wake it and then send the command manually it sends the command fine.
Any help would be appreciated.
