Is there a LUA command to wake a device?
Basically I want to check a certain device if it's marked as dead and then send the command to wake up.
I have one switch device that's up two stories and one other switch is in between but sometimes the command doesn't get there and when I check it's marked as dead.
But when I wake it and then send the command manually it sends the command fine.
Any help would be appreciated.
9 answers to this question
Guest Lode
This will do the trick
To wake up
The script I use:
    Awesome guys!!
    Exactly what I was looking for!
    Thanks a thousand times!
    [ Added: 2014-04-19, 11:42 ]
    Small follow up on this,
    Didn't work for me, it never woke the device, with the correct id ofcourse.
    This one did work, and devices are woken immediately.
    Been running with the first command for a week now, and still devices went dead.
    So I just made two buttons in a virtual device and run both commands, the first one didn't wake them and the 2nd worked fine. So just changed all my lua to the 2nd command so let's see how that works after a week or so.
    On 15-4-2014 at 10:06 AM, boerremk said:
    The script I use:
    conditions
      conditions = { {
          id = 35,
          isTrigger = true,
          operator = "==",
          property = "state",
          type = "device",
          value = true
      operator = "all"
    action
    hub.call(298, 'turnOn')
    hub.setTimeout(20000, function()
    end)
    fibaro:wakeUpDeadDevice(75);
    @Rados
    This should work
    On 3/4/2024 at 7:53 AM, Stycx said:
    @Rados
    This should work
    Thank you @Stycx, it works
    My Fibaro button does not work until I wake it up. It does not go into a "Dead" state; it simply does not respond to any commands until I wake it up by pressing it 4 times. Is there a way to create a Lua scene to automatically send a wake-up command to this active device?
    Use the same hub.call is i wrote above, it works for me
