My motion sensor (FGSM-001) sometimes gives peak temperatures. It looks like this is some quirky bug in the software.
This would bother me that much if the Home Center would not send me messages like this:
My suggestion: When an extremely high temperature is detected (parameter that could be set per sensor or globally) the sensor should double check the temperature and also increase the frequency to send temperature readings to th
