sirKitKat 24
My motion sensor (FGSM-001) sometimes gives peak temperatures. It looks like this is some quirky bug in the software.
This would bother me that much if the Home Center would not send me messages like this:
My suggestion: When an extremely high temperature is detected (parameter that could be set per sensor or globally) the sensor should double check the temperature and also increase the frequency to send temperature readings to the home center (when there is a fire, there is no need to save on battery). The home center should analyse the results and send a notification after several hight temperatures are received or when no communication is coming after one hight reading.
Also, when a warning is send out, but after the one (or more) hight readings, the temperature dropped back to normal temperatures, a new notifications should be send out to tell the users that it was a false alarm.
