I have got a Fibaro single switch 2 built in a switch box. I used to operate it using Domoticz, however that system got corrupted and I was not able to restore the database in a fresh install of Domoticz.
Therefor I decided to purchase a Fibaro Home Center 2. The system works like a charm and I also want to add the Single switch 2. To do that I understood I have to reset the module using the following steps:
Resetting the device:
Switch off the mains voltage (disable the f
