Guest Wiseguy76
I have got a Fibaro single switch 2 built in a switch box. I used to operate it using Domoticz, however that system got corrupted and I was not able to restore the database in a fresh install of Domoticz.
Therefor I decided to purchase a Fibaro Home Center 2. The system works like a charm and I also want to add the Single switch 2. To do that I understood I have to reset the module using the following steps:
Resetting the device:
I think I followed all the steps: shut down the power, removed the switch from the switchbox and pulled out all the wires from the module. Then attached all the wires again, switched the power back on, pushed the B-button for a few seconds until the yellow led turned on, release the B-button and quickly pushed it again...… only I didn't get a red LED indicator telling me the module was restarted and reset. I cannot find the module when I want to add it to my HC2.
What did I do wrong? And more important, what do I need to do to be able to factory reset the module and add it to my HC2?
Deleting it from Domoticz is not possible anymore, because that system is crashed end not working anymore. I must do it like the method mentioned above.... only I don't know what I do wrong.
Pleas help me out.
4 answers to this question
