Showing results for tags 'home center2'.
Found 4 results
  1. I have got a Fibaro single switch 2 built in a switch box. I used to operate it using Domoticz, however that system got corrupted and I was not able to restore the database in a fresh install of Domoticz. Therefor I decided to purchase a Fibaro Home Center 2. The system works like a charm and I also want to add the Single switch 2. To do that I understood I have to reset the module using the following steps: Resetting the device: Switch off the mains voltage (disable the fuse). Remove the Switch 2 from the wall switch box. Switch on the mains voltage. Press and hold the B-button to enter the menu. Wait for the visual LED indicator to glow yellow. Quickly release and click the B-button again. After few seconds the device will be restarted, which is signalled with the red LED indicator colour. I think I followed all the steps: shut down the power, removed the switch from the switchbox and pulled out all the wires from the module. Then attached all the wires again, switched the power back on, pushed the B-button for a few seconds until the yellow led turned on, release the B-button and quickly pushed it again...… only I didn't get a red LED indicator telling me the module was restarted and reset. I cannot find the module when I want to add it to my HC2. What did I do wrong? And more important, what do I need to do to be able to factory reset the module and add it to my HC2? Deleting it from Domoticz is not possible anymore, because that system is crashed end not working anymore. I must do it like the method mentioned above.... only I don't know what I do wrong. Pleas help me out.
  2. Hi all. I am new to fibaro and have started trying different systems to it. The last system which i tried was to add an IP camera from Hikvision model DS-2CD2142FWD-IS. I have tried to add this IP camera. But I didn't get the correct model number in plugins. so i just tried with DS-2CD2132FWD-IS instead. But the problem is that it didnt provide any video for me. and when i searched over internet i found a streampath for this cam..Streaming/channels/102/picture. But it just give me image and I cant view the videoover ther Hope someone will reply back soon noTE: I havent connected the NVD. Hope it will work without NVR with fibaro
  3. my fibaro Home center is not getting detected by fibaro finder. the device is connected using LAN to the network. eventhough the LAN is connected with internet the LED light for LAN is ON, the LED for internet is not ON. I hope some of you will help me soon with regards Moosa Irshad
  4. I just tried to restart my home centre2 from my computer. and it takes so much time. so i just powered the fibaro system manually and restarted it. Now i Cant my fibaro finder is not finding my Home centre2, hope someone will help me soon Thanks in Advance
