Showing results for tags 'ip camera'.
IP Camera support is dead (Dahua, more to follow)
earto posted a question in Other Devices / Third-party devices
IP camera support on Fibaro is about to become history. I love my HC2 but unless Fibaro implement simple "digest authentication" for IP cameras, support is about to die off. Here's why: Recent vulnerabilities have forced some IP camera manufacturers to REMOVE basic authentication. Fibaro ONLY supports basic authentication. Digest authentication has been around since the 90's and is one step above basic or "plain text" authentication (visible in packet captures). It is becoming more difficult to upgrade or buy new cameras that support basic authentication. Dahua - Since early 2017, basic authentication is now disabled in Dahua firmware. - In 2016, Dahua started signing its firmware which stops downgrades to unsigned versions. - So there's no solution once you have newer firmware installed. Not to mention the lack of support for RTSP, with MJPEG becoming obsolete. Digest auth is needed just to keep existing functionality. Beware of upgrading your IP cameras! -
Using DVR instead of IP camera
mehdi deilamani posted a question in Other Devices / Third-party devices
Hi every body! Is it possible to use DVR instead of IP camera? DVR also has LAN port. -
Hi all. I am new to fibaro and have started trying different systems to it. The last system which i tried was to add an IP camera from Hikvision model DS-2CD2142FWD-IS. I have tried to add this IP camera. But I didn't get the correct model number in plugins. so i just tried with DS-2CD2132FWD-IS instead. But the problem is that it didnt provide any video for me. and when i searched over internet i found a streampath for this cam..Streaming/channels/102/picture. But it just give me image and I cant view the videoover ther Hope someone will reply back soon noTE: I havent connected the NVD. Hope it will work without NVR with fibaro
- 6 replies
- home center2
- hikvision
Hi Im trying to find a solution where i can turn on and off the feed from ip cameras into the fibaro interface. I would like the cameras to feed only when the alarm is on. We use the cameras for checking the house if the alarm goes of, but my wife somewhat worried about someone gaining access to the fibaro system would also gain access to the cameras when we are home. There is no such option in the camera settings. Im thinking if it would be possible to define the IP adress of the camera as a fibaro global variable, i could just change the ip to a dummy ip when i want to turn it off. Anyone have a solution for that.
Hi all, I have be trying to get my TP LInk NC250 to work with my setup, so far no luck, tried to follow the tutorals etc. I have a Fibaro Home Center Lite setup. Any tips, ideas would be welcome.
I operate a Axis M3027-PVE (180°). It really works fine with different apps like TinyCam / IPcam Viewer / Synology or even just with a bowser (IR, Edge, Chrome, Safari). HC2 (4.110) doesn't get the stream, although IP, mjpg & jpg links are correct (and can be opend in above mentioned apps/browsers. The Plugin "Axis generic" finds the correct IP of the cam , but does not get the stream or still image. It seems no problem of the right port. Does anyone has an idea ? Including my Foscam and Apexis was no Problem
Hi Fibaro Are there any news regarding H264 support ? Are you working with solutions ? Most new camera models only support H264 stream....
I address this question to Hikvision IP camera users. I've bought camera: DS-2CD2120F-IWS http://overseas.hikvision.com/europe/Products_accessries_158_i8595.html I set up MJPG second stream. I use url like this: http://<ip>/Streaming/channels/1/preview http://<ip>/Streaming/channels/2/preview http://<ip>/Streaming/channels/102/preview ... (tried many similar) Main problem. First connection work fine. But when I try to watch stream from second device(or second tab in browser). Camera returns me error xml. <ResponseStatus xmlns="http://www.hikvision.com/ver10/XMLSchema" version="1.0"> <requestURL>/Streaming/channels/1/preview</requestURL> <statusCode>4</statusCode> <statusString>Invalid Operation</statusString> </ResponseStatus> 1. Please tell me, do you have such problem? 2. I didn't find any info about such limitation in documentation. 3. I updated firmware. 4. Is it possible to turn of such limitation?
The best Integrated IP Camera with HC2
spiderjava posted a question in Other Devices / Third-party devices
Hi All, from your point of view which is the best pre-integrate IP Cameras on the market that could be used from HC2 and have also most of useful functionalities (eg motion, recognition, definition, emergency battery, wifi...)? Thanks a lot in advance. ng--- 16 replies
- ip camera
- integration
(and 3 more)
Hi All, I am new to Fibaro and appreciate that there is a dedicated list of IP Cameras that are compatible with the Fibaro HC2. I have a camera which is not on the list (Chinese Brand) however the camera will work with VLC and is ONVIF compatible. Could anyone point me in the right direction of where I should look to integrate these Cams? Many thanks in advance,
