le"Roller Shutter3" is set to venitian blind (parameter 151 set to 2) Have you found a way to completely cancel the return to the position of the previous slats after a movement (up or down) of the blind? I put the parameter 153 on 0 (by default it is on 1), so if I completely lower the venetian blind with the wall button (connected in S2) the slats remain closed but if I do it with the domotic box, once the blind lowered, the slats open again. there is no parameter to adjust so that
