parameter 153 : "set slats back to previous position"
thsrp
le"Roller Shutter3" is set to venitian blind (parameter 151 set to 2) Have you found a way to completely cancel the return to the position of the previous slats after a movement (up or down) of the blind? I put the parameter 153 on 0 (by default it is on 1), so if I completely lower the venetian blind with the wall button (connected in S2) the slats remain closed but if I do it with the domotic box, once the blind lowered, the slats open again. there is no parameter to adjust so that the slats never return to their previous position. Did you find a solution?
@thsrp, No there is no such setting via parameters.
Some Czech customers requested this feature too.
