Meaby already bin said here but how align the text in QA to the left
tryied
M=string.format('<div align="left">prev_'..t[2]..': '..prev..p_unit..' | new_'..t[2]..': '..new..unit..' '..i..'</div>')
self:updateView(t[2]..'use','text',M)
and also other stuf but no luck
Here is a hack that works using the table tag, you need to specify the width of the label in pixels...
<row ..> needs to be first tag on new line if you want to align the line. Left alignment is default. The row attributes are inserted in the <td> tag for the table.
