Hi people around Fibaro,
I got a question from one customer about popup notifications. I realised that this is nice thing to use for some of us, but there is no info about this function on the forum and nowhere else (except for developers page).
So I created a blog post about this usefull thing. It is in Slovak language, but not hard to understand, as the LUA script is easy.
http://www.homesystem.sk/blog/notifikacie-ako-ich-nepozname
In a shortcut - this notification run when the wall plug 27 is turned on.
The options are for Yes - turn it off and No - leave it like that.
There is one thing I added to the script. Normally, this notification will only pop up when you have the aplication running. If you have it hiden or closed, it wont do anything untill you open the app again. So I added the line to send notification nr 4 to device nr 9. This will send the normal, push notification. After you click on it, it will open the app with the actual notification.
fibaro:call(9, "sendDefinedPushNotification", "4")
You can add 3 buttons but the button can only start another scene, not a device! So you need to create new scene (or use the old one) and add the ID of this scene to the button.
Hope this helped at least a bit. As I said the script is quite easy. It was only hard to get the info about it, so for future referencies
