IPAD Wall Mount
alex88
Has anyone found a decently priced iPad wall mount with charger for the iPad 4?
I have found lots of solutions by they do not support iPad 4 or they are too expensive or they do not allow for easy mounting and un-mounting.
check this one..
basic and simple
  • Please login or register to see this link.
    saw this one, but not sure how you power it neatly though....
    This is the best
    Vídeo:
    No support Ipad 4, soon release it.
    Guest Kuuno
    we are currently working on these. in picture you can see first prototype.
    it will be pretty thin and include wall charging.
    finishing is oak, teak and so on...
    ipad can be taken out also
    Nice, the problem I see is take the ipad and do recharge wall mount.
    Sry my english is very bad.
    Guest Kuuno
    im nut sure if you mean this but the wall mount is charging th ipad!
    regards
    Kuuno
    Guest Kuuno
    the frame is designed to be very thin and does not have to go inside the wall only charging wire part
    ipad slides out from the side very easily. i will do a demo video as i get final product i my hands
    price should be around 80€, it will depend on what kind of wood is used as some can be very exclusive
    What you think of mine.
    Charger included
    Guest Sander
    Charger included
    nice! Where can I buy it and how much is it?
    Guest skeal
    i like these:
    i have one for my nexus 7 ... looking really good. and you have place for putting the charging cable in without seeing it. and then you can take this for charging:
    Charger included
    +1
    I can't see the power option for this.
    The smart things wall mount seems like the clear winner. Pity they don't have the adapter yet for the iPad 4! It's only been out for a year now.
    • 4 weeks later...
    I use this one with the UTP plugs to charge it:
    Charging works oke if you don't use the Ipad(4) to often.
    • 5 months later...
    To bad still no other nice wall mounts on the market.
    I have tested loxone. iPad is not fitting well a bit wrong move and the ipad will drop in the landscape mode (you need this for Fibaro)
    Going to test the Sdock pro. This one looks very robust.
