Düwi 05443 Wall Switch HomeCenter2 Problem
slaughterhouse
Can someone tell me how to include the Düwi 05443 Wall Switch to the HC2? It is recognized by the system but has learning troubles. The Device shows up in the Devicelist but has no function. I thought every z-wave product is compatible. Am i wrong? This is was the log showed on including:
[19] Home Center in learning mode
[19] Device added
[19] ID 30: Controller added
[19] Routing table update
[19] Learning mode error. Try again.
5 answers to this question
Guest minimax
any update on this?
I'm still having this problem.
Cheers,
Petr
[ Added: 2014-04-08, 17:32 ]
finally I have a working solution.
The trick is not to use NIF to include the controller in the fibaro network by triple pressing up or down.
The correct way (according to the 05443 manual) is to put fibaro into the include mode and then hold I (include) button on the wall controller for 2s.
The wall controller is then properly included and configured.
After closing the add device dialog, send NIF (tripple press up or down) from the wall controller. The device is then reconfigured.
If the method above does not work, try to reset the wall controller this way:
hold Exclude button for 10s (until it flashes red yellow green slowly). Then tripple press up button and wait until the flashing stops. Then remove batteries for a minute.
Hope this helps.
It took me three weeks to find this out.
Cheers,
Petr
Hey Minimax,
Ok I succeeded in including the Duwi onto the HC2 but what can I do with it now ? How do I include it into scenes ?
Frank
Hey Minimax,
Frank
+1
I tried to set the Parameters 13 and 14 (1d) to 3 but however it is still not available in scenes...
