Impossible remote access with Fibaro HC lite
javierms
I bought a Lite HC 4 weeks ago and it works correctly for the local network, except remote access.
From beginnig I can not access remotely (4G or ethernet).
From Fibaro have tried to fix it but have not been able to.
Other users have reported similar problems with remote access.
I think it's a problem of the firmware for Lite HC because I've done all sorts of changes to my router and it works correctly.
I hope the new firmware v.4 solve this problem, because if not the HC-lite is an unfinished product and currently not recommended
4 answers to this question
javierms, please contact with [email protected] to check why remote access is not working
  • I do not know the reason but from yesterday the remote access works perfectly.
    Thanks a lot
    [ Added: 2014-04-22, 11:46 ]
    From 6-7 days ago I am not able to remote Access
    [ Added: 2014-04-24, 17:46 ]
    From 1 week ago the remote access doesn´t work. Again
    Hi, I have same problem, remote access is not available and I can solve in two ways:
    I can wait indefinitely, or reboot the device
    You have the same problem and can be solved in this way?
