No Energy Data in Home Center Lite
Guest biasadmin
Guest biasadmin
For the last 3 days there there is no Energy Data in my Home Center Lite. It was working fine before. Does anyone have the same problem?
6 answers to this question
I have a similar problem. One of the plugs is no longer showing energy usage.
When I noticed this I realised the "Show energy consumption measurements" option is unselected but I cannot selected any more.
I am sure this was not done manually and not being able to selected makes me think is something with the system.
Main issue is that if I remove this device I will lose the historic data
Try reconfiguring the device, this won't affect historical data.
After that it should be possible to select "Show energy consumption measurements" again.
thanks that made the trick
Guest biasadmin
  • Real time energy measuring is also not working. All devices are working fine (besides energy management). I am using the FIBARO plug and some FIBARO relays, a shutter module a RGBW module and some other wall plugs. All used to work fine after I declared their power consumption. I also restarted HCL 2-3 times but still I get nothing.
