Synology Surveillance Center
Guest Hakanos
Guest Hakanos
I have tried the solutions here on the forum to control recording my cams with synology and none of them work for me.
It works within a browser but cannot figure out how to implement these 3 commands in a virtual device. I run them as string
First I have to run this command: (login)
Synology = Net.FHttp("192.168.2.20",5000)
Synology:setBasicAuthentication("admin", "XXXX")
response, status, errorCode = Synology:GET("/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=1&account=admin&passwd=XXXX&session=SurveillanceStation")
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
fibaro:log(errorCode)
Then the following command: (start recording)
response, status, errorCode = Synology:GET("/webapi/SurveillanceStation/extrecord.cgi?api=SYNO.SurveillanceStation.ExternalRecording&method=Record&version=1&cameraId=2&action=start")
fibaro:log(response)
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
And the last command: (logout)
response, status, errorCode = Synology:GET("/webapi/auth.cgi?api=SYNO.API.Auth&method=Logout&version=1&session=SurveillanceStation")
fibaro:sleep(3000)
if errorCode == 0
then
fibaro:log(status)
else
What am I doing wrong?
Hi
I can share you a script that runs make by Lazer
Specify ip and port in VD and this code in one or more buttons
Just change the first 4 lines..
for play :
for "stop" :
to direct the camera to a saved preset (PTZ) :
More info, (in french)
Virtual Device :
Guest Hakanos
  • Hi,
    Thanks for the code. But I am getting the following error:
    [ERROR] 11:50:02: line 15: attempt to call method 'getSelfId' (a nil value)
    I am not that great with LUA
    /emoticons/default_icon_redface.gif" alt=":oops:" />
    Fixed, did a copy paste the code from the link and it is working great
    Thank you very much, was looking for this for a very long time
