Integration of XBMC and HCLite
vmuscariello
hi all, I'd like to add a virtual device to control XBMC running on a mac. Is it possible to do it without using LUA code? any help would be appreciated.
see here
  • ciao, it's a bit difficult for me to understand what to do step by step. What I did is:
    - download and setup with IP and port 8080 of Xbmc.vfib
    - download and set up fibaro.addon-0.1.1.zip in xbmc
    it doesn't work. what are the next steps?
    Setting up the virtual device at port 9090 and the above codes of stevenvd work fine.
    The jsonrpc (http api) works on port 9090.
    Volume code :
    if you like a list of all the jsonrpc codes just go to this link when xbmc is running
    :8080/jsonrpc and you get all the options.
    Some code that should in the HCL:
    Turn off:
    Set volume in slider:
    Back Button:
    Home button:
    Info:
    Up:
    Left:
    Enter / OK:
    Right:
    Down:
    Show OSD:
    Play / Pause:
    Eject CD:
    Play music from file location:
    Open weather plugin:
    Post message:
