walter60 0
Hi there,
I am using a Duwi wall mountend relay switch which switches the connected light. However, i would like to use the switch also as a trigger to a scene (all off). Have a hard time getting this into a rule. Is the switch at all communicating to the network if it is pushed, or is this only 'logically' connected to the direct connected light?
regards
Walter
