diderik 6
So, my electrician hooked up an LED mirror on my bathroom.
Contrary to the specs on the V&B page, it says 38W LED on the back, and that is about the only specs regarding the electrics and LED that is available.
The light seems stable and fine, but the problem is that the mirror emits a rather annoying buzzing or humming noise (when it's on) that changes in cycles. It's not very loud, but certainly loud enough to be annoying. And no, it's not on a dimmer, it's behind a Fibaro double relay.
What could be the cause of this? I can hear the electrician or producer blaiming the Fibaro module, but I can't imaginge why that should be -- it's only an on/off switch? If it's incorrectly hooked up, there would be no light at all?
This is a +1000GBP mirror; hopefully I'll get some input here before talking to the elctrician and/or Villeroy&Boch.
Thanks!
4 answers to this question
