lukas.polivka 3
I was thinking of using U-S2A converter to convert signal from Fibaro RGBW controller (24 V 240 Hz PWM) to 0-10 V (or rather 1-10 V) to control "Osram QUICKTRONIC INTELLIGENT DIM CFL" ECG (Electronic Control Gear).
It appears that this ECG (Electronic Control Gear) needs to have the live (phase) 230 V switched off to turn the controller loads off completely, as the ECG only dims 3-100 % using 1-10 V signal. (Or perhaps the ECG is "smart" enought to switch off when the control voltage drops to 0 V?)
Is anyone familiar with any relay capable of staying "closed" when the Fibaro PWM output is at 1-100 % but "open" when the PWM output is off (0 %)? Or a relay which would stay "open" for ~0-0.9… V but "closed" when the voltage level is 1-10 V?
Or do you know about any alternative? (Unfortunately replacing the CFL lights does not seem to be an option.)
U-S2A:
Osram:
[ Added: 2014-10-10, 08:05 ]
An update: It seems that most likely this 1-10 V ECG is actually controlled by resistance (rheostat). I'm trying to get any contact in Osram to confirm this.
On 1-10 V vs. 0-10 V dimming (source:
):And (source:
):Do you have any suggestion / alternative product which would be able to control such dimmer?
(I know, I know, the best solution would be to ditch the light fixtures completely and replace them with anything compatible with either FGD-211 or FGRGBWM-441 directly. But that's not very feasible at this time.)
[ Added: 2014-10-10, 10:36 ]
So I managed to get in touch with a person from Osram (Czech branch) - according to them it is indeed dimmable with variable resistance.
So I'd need PWM to variable resistance or leading-edge type dimmer to variable resistance convertor.
