robmac 173
So lots of us over the past year have suffered from failed USB drives.
The problem is that the USB stick is tied to the HC2. We can guess that it is probably using the USB serial number and possibly manufacturer as a key.
So in the event it happens to you, providing you have a copy of the volumes from the disk prior to corruption you may be able to recover.
We know you can copy from one device to another so before you give up:
Scan the surface of your failed USB. If it is good recover the backup volume back onto the original device.
Sadly if the USB has surface errors it is send your HC2 and USB back to Poland time or swap it under warranty with your retailer.
Regardless it has to be worth making a backup copy as when you get your replacement HC2 from your retailer you can copy files onto the new HC2 and recover as in this post.
5 answers to this question
